Polymorphic icon editor - reverts back to old editor
LabVIEW 2010 SP1
I have a set of polymorphic VIs that I have in a Instrument Library Project in the Public Folder.
When I try to edit the icon and select a Glyph to drag into the icon field LabVIEW reverts to the old editor!
This is really slowing down my productivity.  Is there a way to fix this?
This also happens to non-polymorphic VIs Icon Editor.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(2,775 Views)
http://forums.ni.com/t5/LabVIEW/LV-2009-Icon-Editor-Turned-to-Previous-Version/m-p/1022706#M455826
Hmm I just checked this post out and it seems like somehow my folder got set to Read Only - but even as an Admin I can't change it to not read only...time to call IT.
(2,770 Views)
Accepted by RVallieu
Closing LabVIEW and starting again removed the issue - even though I still can't change the folder access option from Read Only.
(2,767 Views)
Would you be able to send a screen shot of the issue?
Have a great day,
Ben D.
Applications Engineer
(2,746 Views)
I can't now as it was fixed by restarting LabVIEW and it would be pretty hard even if it wasn't fixed.  One minute I had the new icon editor, then as soon as I tried to perform any action in the new editor it would switch to the old icon editor.
(2,721 Views)
