Polynom - Fitting
I want to implement a polynomal function 5th order. I have build a trend line in excel which outputs the correct polynomal formula. (table.jpg)
1. option: who can I implement this formula in labview? (polynom.jpg)
2. option: what is wrong with my current labview code? (code.jpg)
Any hints?
Best Regards,
Joachim
(3,648 Views)
Get the "linear ramp" from the "signal processing...signal generation" palette, pick the desired start, end, and # of points, and wire to the polynomial evaluation (where you currently have the broken wire).
Graph the output together with the original data on a xy graph.
Instead of three pictures, you could have simply attached your VI with typical data as default. It is much easier to show the problem and solution this way.
(3,639 Views)
Accepted by topic author Joachim082
altenbach,
thanks for your response. The scaling of my values aren't linear.
I've attached the example with the solution - I have to work the the polynomial coefficient instead of the best polynomal fit.
Best Regards,
Joachim
(3,627 Views)
I never said they are linear, but if you want to draw a trendline, it makes sense to do a linear x ramp to calculate the polynomial at each point. I thought you wanted to graph a smooth trend line, e.g. as follows.
(3,608 Views)
