Polynomial plotting of my original curve
Hi
I am trying to re-plot my original curve with a best fitting curve. I am using a 3rd order polynomial to do this. However, the output of the fitting is in numeric and not a graph. I could not identify which part of my VI is giving the problem. Therefore, do i use the coefficient to re-plot my graph or using the best polynomial fit is enough to plot together with my original curve.
My intention is that the next step i will subtract the  value of the re-plot curve with the original curve.
I am using LabView 8.6.1
Thank you for helping out
Cheers
(2,898 Views)
The Curve Fitting express vi will output  dynamic data. Otherwise use the convert to dynamic data signal
Greetings from Germany
Henrik
LV since v3.1
(2,880 Views)
