Poor quality sinewave output with cDaq
Accepted by Doug_1970
So here is what I'm seeing (attempting to reproduce with my USB 6343, as I don't have a cDAQ chassis and module handy):
When I run your example as posted, I get chopped up behavior.  I see portions of the waveform repeated, then updated, repeated... wash, rinse, repeat..
When I check set 'Regeneration Mode' to 'Do not allow regeneration', this behavior goes away.  I also do not see this behavior when running the example VI I referenced earlier.
When looking at the output of your 'simulate signal', I see that it is outputting a waveform of 1000 points.  With regeneration enabled, these same 1000 points are getting regenerated until your loop iterates and data is re-written.  With this setup, only data which is written as complete periods will appear the way you'd like.
Things that appear to help:
In 'Simulate Signal', uncheck 'Automatic' for 'Number of Samples, and set it to something bigger.
Changing 'Regeneration Mode' to 'Do not allow regeneration' **Just changing this one setting allowed your VI to work for me.
Dan
Message 11 of 15
(870 Views)
I have tried the example file posted earlier and everything works fine. I will try the other suggestions now and hopefully will get everything working.
I've posted some examples of the waveforms that I have been experiencing with different settings of the sine generator and analog output.
Message 12 of 15
(866 Views)
Dan,
Thanks - that has fixed the problem.
Although I'm sure I tried that yesterday with no difference -  I'm pretty sure I must have closed the window after selecting 'no generation' instead of clicking 'ok'.
Apologies, and thanks for your patience.
Message 13 of 15
(856 Views)
No worries... I've done that 100 times.  Glad to hear that you've got it working!
Dan
Message 14 of 15
(853 Views)
@Doug_1970 wrote:
If I enter any value with a decimal place, then the frequency just defaults to the next highest whole number - i.e. if I enter 0.2Hz, then I get a 1Hz output.
I don't.
Thusly!
Message 15 of 15
(848 Views)
