Pop up window
I had a waveform graph that would update itself with every iteration of a while loop, but then I turned the whole loop into a sub VI. I would like to see how the graph changes with each iteration still, is there a way to make the waveform graph pop up while the sub VI is running? Thank you,
Gregory
(3,712 Views)
Accepted by topic author gjacob
If I understood you correctly, you need to follow the instructions here:
How Can I Control Whether or Not The Front Panel of a SubVI Pops Up When Called in LabVIEW?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,711 Views)
Why not just add a button that says "Show graph" (or something) and then just have an event that handles this by calling an Invoke Node with a reference to the subVI?  This will give you control over when you view it.
Message Edited by mtat76 on 06-11-2010 11:08 AM
(3,704 Views)
I may try not incorporating the while loop in the sub VI and just put it outside in the top level VI
(3,696 Views)
