Populate a ring with an external file after generating the executable.
Hi everyone!
I'm doing a little program in labview and I need to be able to populate a ring from an external file. I have not found any difficulty in doing this, but I would like to know if once the executable has been created this procedure can continue to work or not.
I believe it will work, but I would like to know your opinion.
Thank you so much!!!
(2,018 Views)
Accepted by topic author Giadavid
Yes you should be able to read information from a file and populate a ring.
Tim
GHSP
(2,003 Views)
Resolved. Sorry for the inconvenience.
(2,000 Views)
