Populating a combo box
Is it possible to populate a combo box located in a main.vi from a subvi using refnum? I've been able to do it within the same VI using the property node 'String[]' but this property is not available when used with control refnum. Any tips to do this from a subvi?
(3,224 Views)
Hi Martin,
I think you are having this problem because the control reference input terminal on your subVI is the incorrect class. You can easily create a control reference control that is the right class by dropping a control refnum from the Controls > Refnum palette on the front panel, then ctrl-dragging a combo box into that refnum control. This will create a control refnum control of the appropriate class for you to use in your subVI.
Good luck,
-D
(3,224 Views)
Hi Darren,
Thank you for this. I did not mention in my first post that the combo box was in a cluster. I've been able to do what I want by using a vi that is new to me: 'To more specific class' and attaching a Combo Box Refnum constant as target.
Thanks again.
(3,224 Views)
