How to link to a VI in an EXE
Hi All,
I have two modules of code. The first is either in VI or EXE format, the second is in EXE format. I want the first module to link to a VI in the second using call by reference node. I find that when I try this I get error 1003 (The VI is not executable.) even thought I know it is functional.
Has anyone attempted this? Or can any one explain this behaviour?
Thanks for your help
Denis
(2,959 Views)
Well, there are a few issues here. First if you want to load the VI from your other application you will have to either reference it by the path
/otherapp.exe/yourVI.vi or alternatively using VI server open a reference to the other executable and then opening a reference to the VI through the VI server of that application. For this to work you have however to enable the VI server of the other application. You can do that most easily by configuring VI server in your development system and copying the according labview.ini file settings into your otherapp.ini file.
Complicated? Yes of course, but there are a few reasons to do it that way.
1) If the LabVIEW runtime systems are not exactly the same you will get trouble loading the VI from one executable into the
other executable.
2) If you load an external VI in an executable it usually has subVIs. If one of those subVIs happens to have the same name as another subVI in your caller executable, the LabVIEW runtime will try to link to its own subVI instead and if the connector pane of those two subVIs isn't exactly the same the externally loaded VI is not executable.
Rolf K
Rolf Kalbermatter  My Blog
(2,959 Views)
Denis Jolivet wrote:
> Hi All,
> it is functional.
howev
trouble loading the VI from one executable into the other executable.
Rolf K
(2,959 Views)
