lvrt.dll error on Windows XP
I had an application built using LabView 5 on Win98 system and it was running perfectly, I decided to upgrade the system to Windows XP,then, i used Labview Run-Time Engine 5.1.1, i was surprized when the application ran perfectly also (I know that 5.1.1 works only till Win2000!!!), BUT, after 10 to 15 minutes from idle process, i get an error from WinXP saying that there was a problem in my exe file because of (lvrt.dll), when i restart the application it runs OK.
I'd like to add more info:
- The application is using Traditional DAQ Card.
- The application includes ActiveX & Networking.
- I don't have the source code to modify anything.
Any one has a clue what to do to avoid this error????
(3,013 Views)
Do you get the error everytime you run your program? Since you cannot edit your code, you might try reinstalling the drivers and the LabVIEW RTE. There is not really a whole lot to be done for troubleshooting because of the lack of source code. You might see if you can transfer the application back to a 98 machine if nothing else helps.
(3,013 Views)
Thanks Jeremy, But i have to use a powerfull machine with high configuration, the processor of the machine is 800 MHz Bus Speed, which the 98 can't run on, so i have to use either 2000 or XP, i forgot to tell you that on 2000 i get an error when i try to start the application and when i click ok, it runs perfectly !!!! kind of complicated isn't it????
I can't come up with a solution, can any one????!!!!
(3,013 Views)
