Populating ring text from sub vi - How?
I think I'm heading down the Rube Goldburg road and need some advice .
I have a front panel running some test equipment. The user 1st selects a test fixture and I populate the available test methods from reading a simple *.ini configuration file specific to the selected fixture. Where I'm having problems is when I populate the ring control using a property node I just can't figure out a clean way to populate the front panel from the vi. I'm just trying to pass the ring text to an identical ring control on the front panel; the user then selects the desired test method which I later load and run the test.
I'm sure it is something simple that I've forgotten but I can't figure it out without going all Goldburg.
-Chris
(Oh man the snippet function butchered my vi; here is a jpeg).
Message Edited by F1_Fan on 09-01-2009 09:39 PM
Message Edited by F1_Fan on 09-01-2009 09:40 PM
Message 1 of 10
(6,645 Views)
Take the reference of the Ring text inside the subvi and update the Values.
http://forums.ni.com/ni/board/message?board.id=170&thread.id=428582&view=by_date_ascending&page=1
Message Edited by Baji on 09-02-2009 08:45 AM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 2 of 10
(6,625 Views)
Accepted by F1_Fan
If I understand you correctly you are looking to populate the Strings[] property of a Text Ring on the main VI from inside a subVI (I assume the code you showed was from the subVI).  In this case, I would use a Control Reference.  See the following example.  Hope this helps.
Message 3 of 10
(6,624 Views)
Thanks for the help; that solved my problem is a nice clean way.
Learn something new everyday!
Message 4 of 10
(6,578 Views)
I don't see the point of these solutions that use a reference and updating the main's control there. All you have to do is pass the string array back to the main and write to the control's property node.
Message 5 of 10
(6,574 Views)
When you are in a state of a State Machine that in turn is in a SM that is a SM....
Control references let me keep the GUI updated without having to return to the main.
Ben
Message 6 of 10
(6,562 Views)
Okay, that makes sense but do you think that is what the op is doing?
Message 7 of 10
(6,557 Views)
The words don't sound that way but the screen shot makes it look like he wants to do it in a sub-VI where they have the right idea but they are pointing at the wrong widget and want to poke at a callers ring control.
Ben
Message 8 of 10
(6,551 Views)
It is part of a much larger multiloop QSM and my problem was indeed updating the control from inside a state inside a subVI.
The application is growing (as well my coding skills) so I'm trying to use good practices. I used the control ref technique but will be expanding it even further. Decided to put all the front panel controls into a cluster and type def the cluster. I can then easily update those controls (and add more) without large wire changes.
-Chris
Message 9 of 10
(6,543 Views)
-Chris
Good idea!
I put them in an Action Engine so I grapb wahtever I need where ever I need it.
Tip!
When initializing check for the vailidity of all of your refs.
 There were many times when I put every thing together but forgot to add the ref to the actual control. The check let me no at start-up time that I forgot something rather than trouble shooting "why am I getting an invalid ref error" and "where".
Ben
Message 10 of 10
(6,535 Views)
