Porblem with sensor(Thorlabs PM100D)
Hi, I have a problem with reading a sensor's value after each loop operation. My setup consists of the stepper engine with Arduino Uno with Labview. Engine performs movement that includes multiple steps and after each step I would like to read the sensor's value. Unfortunately, sensor somehow outputs value after all iterations instead and I have no idea what I should do to make it output value after each iteration. Thank you in advance for any help.
(931 Views)
It is clear that your implementation has a problem but we can't review/edit them as you did not attach the VI.
Santhosh
Soliton Technologies
(916 Views)
Sorry, It should be visible now
(901 Views)
