Portability issue with "scan from string"
I need to parse a string to recover some info from it, the string contains geometrical properties of a drilling tool written as a series of five numerical values and a name, for example:
"0, 0.250, 20.000, 0, 0, Con20°_0.25mm"
I did something like this:
and it works:
The problem is that when I use this code with the same example string from another computer it doesn't, both computers have the same version of labview (2017 32 bit), how is it possible?
Message 1 of 8
(3,375 Views)
Hi Antares,
Have you checked taht both computers use the same Regional and Language options ?
Maybe one is using a '.' (point) as decimal separator whereas the other one uses a ',' (comma).
CLAMaxime -- Kudos are a great way to say thank you
Message 2 of 8
(3,372 Views)
I agree with Maxime on a possible cause.  If you read the Help for this function, you will see that you can set/override the decimal separator by using what LabVIEW calls the "localization code syntax elements".
Are you not parsing at all that last quantity (Con20°_0.25mm)?  You could pull out the "20" part and the 0.25mm part as two more values (or just the 0.25, as you wish).
Bob Schor
Message 3 of 8
(3,360 Views)
Actually they use different configuration for '.' (dot) and ',' (comma).
I tried to set it up properly but it is still not working, I tried from the control panel on windows but probably there is something on labview option panel, can it be?
No it's ok like this because it is just a name, and the values inside (for example 20 or 0.25) can still be recovered from the numeric array  Smiley Wink
Message 4 of 8
(3,345 Views)
I tried with Tools/options, disable "use localized decimal point".
Now it's working!
Thank you Smiley Happy
Message 5 of 8
(3,334 Views)
I'm not sure the solution you found is the ideal one. When the VI is compiled to an exe or used on a different system this setting might be lost.
Just prepending %.; in front of the format string (this will force the use of . as decimal point) seems the better option.
Message 6 of 8
(3,332 Views)
dan_u is correct.  You really should just set your format string to be:
%.;%f,%f,%f,%f,%f
The %.; forces the format to use the period as the decimal separator.  And just for completeness, you can use %,; to use comma as the decimal separator.
GCentral
Message 7 of 8
(3,309 Views)
Perfect, thank you all!
Message 8 of 8
(3,270 Views)
