Repeated calls to Dynamic Event
Hi There,
Hi There,
Just wondering what is the proper way to make repeated calls to a dynamic event? I have an event triggered (timer starts when "Collect" button is selected) that can either a) run until completion (e.g. 10 s) or be cancelled (e.g. user selects "Cancel" button). The user may want to hit "Collect" again but I found I could not trigger the event again.
Thanks in advance,
Anton
(3,079 Views)
If you attach your VI (not a picture, but an editable, testable, VI), we can better understand your difficulty and suggest a solution (rather than guessing).
Bob Schor
(3,066 Views)
First thought: you don't have your event structure in a proper loop or you are stuck in a loop that is inside of your case structure.  Either method will lead to MAJOR issues like you are stating.  But, as already stated, we need to see your code in order to give you any real advice.
GCentral
(3,031 Views)
Make sure that you are polling for event when you are triggering the collect button.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,013 Views)
Here is the basic program that I could trim down to. Basically I want to be able to hit "Collect" followed by "Cancel" as many times without interrupting the streaming and the timer resetting each time.
(3,004 Views)
I didn't see a "Collect" nor a "Cancel" button on your front panel.
I looked at your block diagram, but it was way too messy for me.  I don't clean up other people's messes.
If you want someone to help, submit something that doesn't look like a rat's nest.
(2,978 Views)
