02-05-2008 09:49 AM - edited 02-05-2008 09:56 AM
02-06-2008 02:31 PM
02-06-2008 02:48 PM
Yes, I'm using the file in my project.
Renaming the file is a pain because I have to also copy rename the hierarchy of NI-Motion vi's that call it, to differentiate them from the NI directory vi's that will be called when I open the project on another computer.
I will find a workaround. I just wanted to verify that the NI filename really does have a forward slash.
10-08-2009 02:45 PM
10-08-2009 02:52 PM
Here is the fix for LV 2009 Build issue with forward slash in .llb vi file name.
Step 1) In project explorer -> Build Specifications -> Right click your executable build and go to properties.
Step 2) Go to Advanced tab and check "Use Labview 8.x File layout"
Now you can build your project without the forward slash issue.
Cheers,
Farhoud
