Possible bug in Polymorphic AI Single Scan?
I'm trying to use the AI Single Scan VI to read a set of 3 analog input
channels (2 differential, 1 rse) under LabView 6i, but I'm having some
strange problems. The output is polymorphic, so I select the output type I
want by popping up and going to "Select Type" and picking the output style
I'm looking for.
Here's the problem: I cannot get the Single Scan to reliable return Scaled
& Binary data at the same time! Either "Scaled" or "Binary" mode works, but
when I select "Scaled & Binary" it only returns data in one of the two
arrays--the other is left empty. What's more, the array which contains data
seems to depend on the _last_ way I had the VI configured (i.e. if I do
"Binary" and then "Scaled & Binary"
it returns the binary data but NOT the
scaled, while conversely if I start with "Scaled" and then select "Scaled &
Binary" it's the scaled data that gets returned properly.)
This looks to me like it might be a bug in LabView 6i. I haven't
exhaustively tested it, but what I'm doing isn't exactly complicated, and I
was able to do the same thing back in Labview 5.x.x with no difficulty. Is
there something I'm doing wrong?
Justin Goeres
Indio Systems, Inc.
Pleasanton, CA
(3,016 Views)
Justin,
This sounds like an issue that was reported in NI-DAQ 6.8. It has since been fixed in NI-DAQ 6.9. I would recommend updating your NI-DAQ driver and see if that fixes the problem. You can download NI-DAQ 6.9 from www.ni.com/softlib.nsf/. Hope this helps.
Erin
(3,016 Views)
