Possible to branch off task for a specific physical channel?
Hey all,
I'm using an event + case structure state machine to simulate various sensors/ actuators/ etc.
When the vi is started, I automatically initialize the physical channels on my cDAQ module (daqmx, not daq assistant) using it's own case statement, and then save then bundle the channels/ task separately.
Each button on the front panel then cooresponds to a separate case where I write the appropriate data to that particular channel (14 channels total).
I.e. VI starts --> cDAQ module initialized --> user presses 'Open Valve A' --> Event for valve a executes --> Case statement for valve A (only one channel) writes x-volts to that channel --> re-bundle to task which contains all 14 channels --> wait for next event.
I'm running into an issue where I am unable to branch my task to reference specific channels. For instance, I am forced to use the task which references ALL 14 of my channels, but I only want channel 0.
I've tried using various combinations of arrays, but it doesn't seem to like that very much. My latest approach is:
Create physical channel reference with all 14 channels --> create virtual channel --> bundle that task as 14 separate tasks in a single array. Still getting issues with mismatched data types though.
I'm wondering, is this possible? I'd rather not make an individual physical channel/ 'create virtual channel'/ task fourteen times, but I'm thinking this might be the only way.
Open HITL Primary - WORKING COPY. The case "Init_ni9264" is where I create my necessary channels. On the following case ('HITL_SVBB_SHT') I want to write a voltage only to channel 0.
Thanks for the help!
(3,483 Views)
Accepted by PFour
Hi P4,
when you define a DAQmx task with 14 channels then you get a DAQmx task reference for that task. There is no way just to read or set just one of those 14 channels in the task, you need to read/write all of the channels.
But why is this a problem for you?
Why don't you use some kind of buffer (like a shift register, FGV, AE, globals, whatever) to keep the current value of all channels and provide a way to set/read just one of them?
You seem to have created a state machine with this loop: store the current values for all channels in a shift register. When you want to update just one channel: update that one channel in the array stored in the shift register and output the full array using DAQmxWrite…
(3,428 Views)
Accepted by PFour
Gerd's advice is solid, but there's another alternative if this all operates in human-operator time rather than precision-electronics time.
It wouldn't *necessarily* be so bad to create 14 separate 1-channel tasks.  Since it sounds like all the outputs are on-demand software-timed signals, they can all be configured *and* started without interfering with one another.   You could do this once before your main loop so they're already all in run mode, thus avoiding the overhead of config-run-clear that concerned you.
Note that here are much more serious restrictions when tasks are hardware-timed with buffers -- most devices only allow 1 hw-timed AO task to be running at a time.  (Same for DO on devices that support hw-timed DO at all).   As a matter of fair disclosure, since I habitually do hw-timed tasks where all channels *need* to be in one common task, I would probably tend to approach your app Gerd's way rather than the alternative I described.
-Kevin P
(3,415 Views)
Gerd: Thanks for the input. Yep, maintaining previous values and updating only the channel-of-interest is the solution I ended up going with. Good to know that it is not possible to split up tasks! Thanks!
Kevin: Also a great solution, however I was trying to avoid creating config sequences/ case statements for 14 channels... because that is nightmare fuel. Thanks for the input!
(3,405 Views)
