Possible to change keyboard input language programmatically ?
Hi to all! So as the title says, if somebody has 2 or more input languages installed in Windows is there any way in LabVIEW to get the current language and change that to the preferred one? I have a string control which needs to accept only english characters to avoid problems
Message 1 of 9
(8,363 Views)
Language bar => settings => Advanced Key Settings, create a shortcut for English.  For example Ctrl+Shift+0.
Simulate a keyboard press, and send it your window.
George Zou
Message 2 of 9
(8,290 Views)
Another option could be to filter your input to the control by using the "key down?" event.
Message 3 of 9
(8,270 Views)
Thanks, zoo.I agree that this would be an easy solution but it's kind of personal one. I don't think it would be convenient for deployment of an application
Message 4 of 9
(8,250 Views)
Can we assume English (US) is installed?
George Zou
Message 5 of 9
(8,232 Views)
Use Windows API post a message (WM_INPUTLANGUAGECHNAGEREQUEST = 0x50) to the window:
PostMessage(hWnd, 0x50, 0, 0x0409);
0x0409 is US English.
George Zou
Message 6 of 9
(8,213 Views)
Accepted by blackfinger
For those who are not familiar Windows API, try this llb.
George Zou
Message 7 of 9
(8,179 Views)
Hello Zou,
thank you for posting Inpullanguage.llb.
Although in my case Set InputLanguage.vi doesn't seem to work. Keyboard layout wouldn't switch when I execute it.
Enumerate InputLanguages.vi and Get Default InputLanguage.vi work just fine.
I wonder if it could be caused by some Windows background service not running?
In VI i'm working on I need to set ENG-US keyboard layout to avoid mistakes as user inputs data.
My set is as follows:
LabView 2020 full 32-bit
Windows 10 Pro x64
Message 8 of 9
(4,673 Views)
The demo vi works fine on my Windows 11 with LabVIEW 2021.
George Zou
Message 9 of 9
(4,599 Views)
