Power Spectrum vi
Can anaybody tell me the maximum size of an array that can be accepted by
the Power Spectrum vi in the signal processing toolset?
I find that it does not produce an output if an array size of over 5 million
elemnts is used, however it produces the required output when the an input
array of 4 million elemnts is used.
Additionally, when an array of 5 million element and over is used as the
input:
1. No error message is produced.
2. This occurs even when averaging is activated.
Luca
(2,795 Views)
I am not sure which VI you were using exactly. Is Power Spectrum.vi on the palette Function>>Analyze>>SIgnal Processing>>Frequency Domain? I have tried this VI and do not have the problem you mentioned.
Would you attach some testing VIs?
(2,795 Views)
