I was working with the tree control, and it seems that if you do not specify a tag, the tag is automatically set to be the same as the text. Therefore, when you use the "Get Child" or "Get Parent" or similar function to retrieve the tag, it retrieves the text. Does this work for you?
Hope this helps!
Liz Fausak
