Powerpoint ActiveX control
I am writing a vi to run MS Powerpoint, load multiple presentations and then play whichever one is selected. Based on the ActiveX controls in pptpresent.vi.
I can't find a function to change the ActivePresentation property, so I either keep opening and closing the MS application, or I have multiple copies of the application open at once for each presentation.
Any ideas?
Many thanks
(4,342 Views)
Any ideas?
Many thanks
The MS web-site indicates that property is read only.
Ben
(4,340 Views)
Accepted by grahamwebb
The "_Presentation" object has a "Windows" property, which is a Collection you can index to get a specific DocumentWindow object, which has an "Activate" method.  Maybe try that?
(4,330 Views)
That works perfectly! Thank you Kyle.
(4,313 Views)
