Pre-Programmed Sequence of Outputs
I have built some basic gearbox controllers in LabView and the all work independantly as expected, motor speed, torque demand etc...
What I am looking to do now is develop an automated swquance to act as a sign-off on these gearboxes. Once the technician has perfromed the basic functionality tests I want to run an automated script which is time based.
I have configured the controls using the DAQ assistant function blocks so it is all very simple at the moment and I'd like to keep it that way if possible.
Thanks in advance.
Richard
(2,324 Views)
Hi Richard,
I suggest using a basic state machine approach here: each step calls a gearbox controller setting and waits for a certain time...
(2,316 Views)
