speed sensor
My objective is have my output of my encoder come into a daq assistant. Then covert that to rev per second. Then compare that to what the user sets the speed and adjust it. But I can not get past how to work the daq assistant I cant get a wire to come out of it.
(4,331 Views)
The daq assistant uses dynamic data. You can use a converting block to get the data out. Most likely LV will already do this for you.
Though i recommend you to use the DAQmx blocks, this will give a lower latency in most cases.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
(4,312 Views)
what im saying is I can not get the wire to come from the daq assistant do I have to have it hooked up? physically I just need the block diagram for a visual for a project right now.
(4,302 Views)
like this is my speed sensor an motor control. What I want is the user to enter the motor speed, then have a set motor speed that they can not go above an if they do the brake will be applied. Am I on the right track can someone help lead me in the right direction?
(4,296 Views)
I don't really get what you are trying to explain.
When you are trying to set the speed of a motor you most likely need to build a closed loop too. In open loop the speed wont be that accurate.
But is this what you meant?
(4,292 Views)
You can also use In Range and Coerce to force the Set Motor Speed to be between 0 and Max Speed.  One function instead of two.
(4,279 Views)
Ravens option is better because you can also add a minimum value.
The last option you can do is to enter the numeric control option and to this:
Though I don't know how reliable this is.. It is obviously the most space saving.
(4,274 Views)
