Pre-build vi to set a global
Hi Gerd
Yes thats clear. But the cluster is part of a main.vi which is always the same. Only the values from them should be changed.
best regards
Message 11 of 12
(584 Views)
Hi mazim,
You cannot change an enum without changing the containing cluster.
Think about using a ring instead (maybe combined with some configuration files)…
Message 12 of 12
(580 Views)
