Preference to CHM file LabVIEW 2022
I want to enable the CHM file help instead of going to the internet on my internet connected PC.  I did not find a preference setting for this.  Can this be enabled without disconnecting my internet cable?
As I understand there is new offline viewer coming but I want to use the CHM for now.
(1,392 Views)
Accepted by topic author richjoh
There is an application 'NIHelpPreferences.exe' (maybe here C:\Program Files (x86)\National Instruments\Shared\Offline Help Viewer).
But the offline documentation is no longer a chm file.
(1,385 Views)
Thanks for the info.  Looks like you must run the Offline Help Viewer "exe" executable manually to avoid the web browser opening to LV Online Help Viewer.
(1,304 Views)
If you found yourself here, this post may give further solution.  LabVIEW Offline Help Preference
(1,256 Views)
