Pressure sensors
Hi Natig,
btw. naming a VI "final version" and "trial 3" at the same time is a contradiction in itself… 😉
Message 11 of 12
(268 Views)
Hi GredW,
haha you are right, everytime I think i am done, labview throws me new challanges that is why I am trial of final version.😂
Using both channel at once was indeed the solution for ULx as well . For the ones having same problem: create constant at create channel and then edit names of channels. adding multiple channels is possible
Now I got one more problem.
Now I can not get time in X axes. X axes maximum show always same number with 'samples to read'
I asked chat gpt and read old forums in ni communty. Based on that I have added an empty array to chart history node of waveform chart. But this did not worked.
I just want to see time in x axes, which should run as normal seconds. I changed chart history to 30 because I just need to see what happened in last 30 seconds.
Also I am not sure about all the sample rate, sample to read, there is also sample per channel in timing vi,  and number of samples per channel in read vi. I just need 2 sample in a second to see in write to measurement file later.
Message 12 of 12
(250 Views)
