Prev measurement history on XY-graph
Hi!
Have the system where countinously measuring same poins over and over again. These points are in X-axis and measuring result on Y-axis. I have tagged two different solutions what I have tried. 1, where is buffer (founded on example) and 2, where is used arrays and shift register.
Problems:
solution 1. When coming back from point 10 to 0, plot drows that return.
solution 2. Arrays now initialized to 0 and no history. But if no initializing at all, history is endless.
Have any other solutions to do this?
-Thx, again-
Message Edited by Alias A on 06-04-2009 09:05 AM
(3,638 Views)
Accepted by topic author Alias A
I made the vi so that you can adjust the chart history as wellas the speed. You can use the same concept for the chart graph. I hope this helps.
Tim
GHSP
(3,607 Views)
Nice nice nice.... thank you 🙂
(3,572 Views)
you are welcome
Tim
GHSP
(3,561 Views)
aeastat can u please post the vi in 8.5 labview.... I have kind of similar problem..where, I'm acquiring torque and speed data with DAQ and then i want to plot torque v/s speed...
thanks..
(3,397 Views)
Here you go.
Message Edited by aeastet on 11-19-2009 08:00 AM
Tim
GHSP
(3,380 Views)
