Previous version LABview
@altenbach wrote:
@RavensFan wrote:
@altenbach wrote:
@RavensFan wrote:
Crossrulz's link has a downloader.
Only if you are under SSP.
Does that mean the download link doesn't show up if you aren't logged into NI.com with an address associated with an SSP?
Yes.
I guess that makes sense.  Kind of annoying though.  How would it work if somebody had a student license?  I guess they would have to associate that license with their account first.
Message 11 of 14
(854 Views)
@crossrulz wrote:
@altenbach wrote:
Yes.
Well, honestly: Why should NI provide downloads for tool versions which are not the most current?
This is a policy i understand (only provide the latest which is covering all current OSes) which, i respect that as well, is not liked much by customers.
Point is: LV 8.6 is far from "up to date" hence it would already be a support issue.
Regarding the download: I am not sure if it really requires SSP. SSP is a trackable way of proving to have a valid license (which grants backward activation!). But i can imagine (havent tested though) that a valid serial number of a more up-to-date version should be sufficient to get that link.
Providing the link without SSP or valid serial is something i wouldn't do......
Norbert
Norbert
Expert: Geometry
Message 12 of 14
(848 Views)
My observation was based on the fact that if I log out, the page changes to the following:
The link to SSP benefits explicitly mentions previous versions. I do think that a valid serial number of a later version should be sufficient, but I cannot test this.
Message 13 of 14
(827 Views)
Well, as it is explicetly mentioned as benefit for SSP, i would expect "a simple serial" to be not sufficient to get that link to work.
Maybe a product suggestion?
Norbert
Norbert
Expert: Geometry
Message 14 of 14
(819 Views)
