Ian,
this probably isn't the most efficient method, but you could have 2 'printing'
vi's that are set to print on completion, have one setup to print portrait
the other landscape. The one you call depends on users selection (boolean).
To change print mode for each vi, go to File->Print and select landscape
or portrait.
"Ian Riley" wrote:
>>Does anyone know a method of programmatically changing the orientation
(portrait/landscape)>of a VIs front panel when printing it (i.e. so that
the user can select the>print orientation)?>>Thanks>>Ian Riley
