Print diagram on a plotter (ANSI-C)
I want to print my labview diagram on an HP plotter(ANSI C).  Is it possible?  Can I export the diagram into an ANSI-C sized pdf file?
kasus
(2,815 Views)
Accepted by kasus
You should have a driver installed to be able to print to the plotter. If you have that then you can simply use the File -> Print... command to select what you want to print.
(2,803 Views)
