Print report with Adobe Distiller X
Anyone used Adobe Distiller X ?
Old LabVIEW application works fine on Windows 7 32 bit not working right on Windows 7 64 bit:
It ignores the filename set in the registry, pops up the save as dialog window.
Is this the 64 bit issue? i.e. 64 bit spooler not compatible with 32 bit LabVIEW application?
George Zou
(3,544 Views)
This isn't an answer, but you aren't the only one to experience this:
https://forums.adobe.com/thread/1051403?tstart=0
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,529 Views)
Nice try.  But no, that wasn't it.
Entry under Wow6432Node got ignored too.
Besides, the exe is in LabVIEW 32 bit (the OS was 32bit).
And "LastPdfPortFolder - splwow64.exe" got created under 32bit registry.
Thanks for reply.
George Zou
(3,515 Views)
Accepted by topic author zou
Problem solved.
the last post at:
https://forums.adobe.com/thread/1130786?tstart=0
George Zou
(3,502 Views)
