Threshold Triggering Using DAQ Assistant
Hi to all
I am using pressure transducers to acquire pressure signal using the DAQ assistant. Is there any way that I can trigger the acquisition of signals after the pressure is more than a certain value?
Thanks in advance
(4,207 Views)
What sort of device? You need to look at the specs to see the types of triggering that are available for it.
(4,202 Views)
The device that I am using is NI USB-6531
(4,192 Views)
Do you actually mean the 6351? That's a multi-function device with analog triggers. I'm unsure about the DAQ a Assistant. With Help> Find Examples, you can find code that uses the DAQmx functions to setup a triggered acquisition.
(4,179 Views)
Yes, you are right its NI USB-6531.
Thank you Dennis, I will try this
(4,167 Views)
