Printer selection
LabVIEW normally prints to the default printer. Can anyone help with a vi to select the printer before printing the frontpanel or diagram in an application?
Peter Vijn, Organon Newhouse, Scotland
(5,392 Views)
Hi Peter,
a way to do it is to use Windows API.
- for Win95, use OpenPrinter()/SetPrinter()
- for 3.1/95/NT use WriteProfileString()
You can find details in MSDN Library - articles Q135387 and Q140560.
(5,392 Views)
I got this VI from the Developer Exchange.
(5,392 Views)
Thanks a lot Dennis for this useful routine. It works fine, the only problem is that the diagram is password protected. Do you know whom to contact for the source code?
(5,392 Views)
Nope. I just use it as is.
(5,392 Views)
(5,392 Views)
These 2 VIs uses ActiveX calls to get the printer list and set the default
printer.
Jean-Pierre Drolet
Scientech R&D
"Peter Vijn" a ?crit dans le message news:
506500000008000000F4290000-998975444000@exchange.ni.com...
> an application?
[Attachment GetPrintersList.vi, see below]
[Attachment SetDefaultPrinter.vi, see below]
LabVIEW, C'est LabVIEW
(5,392 Views)
