Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
i am trying to sample 2khz signal at 8khz,with an accuracy upto 6place of decimal ,using pci 1200 DAQ card.
AB 8
Member
08-27-2001
11:03 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
how can i externally trigger this operation.i need to sample my signal at 4 points and store it in a excel sheet and the values should be same,as the the 2khz signal and the 8 khz signal both are comming from the same source.
0
Kudos
Message
1
of 3
(2,583 Views)
Reply
Re: i am trying to sample 2khz signal at 8khz,with an accuracy upto 6place of decimal ,using pci 1200 DAQ card.
Filipe A.
Active Participant
08-28-2001
10:30 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
AB;
We will probably need more details about your application to better help you.
Filipe
0
Kudos
Message
2
of 3
(2,583 Views)
Reply
AB 8
Member
Author
08-28-2001
11:12 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
could u tell me what more details would be required....i will be more than glad to let u know about it.
0
Kudos
Message
3
of 3
(2,583 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
