i am trying to sample 2khz signal at 8khz,with an accuracy upto 6place of decimal ,using pci 1200 DAQ card.
how can i externally trigger this operation.i need to sample my signal at 4 points and store it in a excel sheet and the values should be same,as the the 2khz signal and the 8 khz signal both are comming from the same source.
(2,589 Views)
AB;
We will probably need more details about your application to better help you.
Filipe
(2,589 Views)
could u tell me what more details would be required....i will be more than glad to let u know about it.
(2,589 Views)
