Printing TIF ( picture ) file, how ?
I need to write a LabView application that take TIF picture file from
a disk and print it using the default printer which is connecting to
the computer.
Any idea how to do something like this ?
Thank you,
Noam.
(2,879 Views)
There are a number of ways to do this. I would suggest using a run-line command with an executable that is capable of handling TIF images. LabVIEW with IMAQ can handle it, but I can't think of an easy way to get the image into LabVIEW for printing (IMAQ is usually concerned with display and file I/O, not printing.)
The runline command is going to be difficult to figure out. This is the same things as putting a command in the "Run" function on your start menu in Windows.
Another option is to use ActiveX. However; that means controlling an application that is able to print tif images. I can offer even less help on this solution.
There is a way to do it in LabVIEW, but I can't find any TIF image functions outside of IMAQ, which means somehow convert
ing it to BMP, JPG or PNG, formats supported outside of IMAQ.
You could also put in a support request to NI at ni.com/ask. They should be able to offer solutions.
Good luck
(2,879 Views)
Thank you very much, you gave me some good and importent points that i
can check now, it's really help me, thanks again !
Noam.
Labviewguru wrote in message news:<5065000000050000001E640000-1012609683000@exchange.ni.com>...
> Another optio
> functions outside of IMAQ, which means somehow converting it to BMP,
> Good luck
(2,879 Views)
