Printing a report and using the print dialog for it
i already have the print dialog vi from NI. I am using the normal report generation toolkit for printing reports. But I want to give the user an option to choose the number of pages and landscape/portrait options. But how do I integrate the 2 so that before printing the user can select these features.
(2,682 Views)
There is an activeX control that will set these settings. It is called IAS Helper COM Component 1.0 Type Library. It operates the Windows printer configuration program. Since another company wrote the code, I do not have the resources to help you use the control, but the attached example program should get you started.
Jeremy Braden
(2,682 Views)
