Probability Density Function
I have pressure signals vs. time I need to plot Probability Density Function
but I was not be able to plot it. as I run I  will get just a single point not a countinous
graph. would you please tell me how to fix it.
thnaks for you attention.
attached is the program.
(5,134 Views)
Double click on "Convert dynamic data" and choose an 1D array.
Then for each data perform the "Continuous PDF.vi"
(5,126 Views)
Hello
thanks for your reply. I have done what you mentioned but it seems that
sink (PDF) does not accpt 1D array. sorry for asking.
thanks
(5,121 Views)
If you want to perform the operation for each element, and have as a result an 1D array, you should do
something like this....
(5,105 Views)
