Problem: Building an Installer for NI-IMAQ USB cameras.
Hi everybody,
I start this new thread although another member started it last January.  http://forums.ni.com/ni/board/message?board.id=170&message.id=293125
I have built an Installer for NI-IMAQ USB cameras because I would like to work without installing LabVIEW. My problem is that the application only runs in the computer where was created. I have LabView 8.6 professional version (NI-IMAQ 4.1 and LabVIEW Run-time Engine 8.6) in two different computers but I only have NI-IMAQ USB where the project was created.
In my second computer the executable was installed correctly but when I try to open the application, it appears the warning Missing IMAQ USB (Loading: ImaqDirectShowDll.dll and searching: Myapplication\instr.lib) so that the program does not work. Therefore, I think that this application would not work without LabVIEW either.
The project, application and setup are attached.
Could anybody tell me what my problem is?
Could I really build an installer for NI-IMAQ for USB camera?
Thank you very much!
Best wishes,
JL
(2,882 Views)
Hi JL,
Having been investigating this issue this morning I have found a KnowledgeBase article which directly addresses your issue, which I have linked below.
Requirements for Computer Running an EXE Using NI-IMAQ for USB Functions
I am confident that this will solve your problems.
Best Regards,
Christian Hartshorne
NIUK
(2,860 Views)
Hi Christian,
Thank you very for your help!
I go on slowly with this program because I have had a new problem (Error1074396024 occurred at IMAQ USB Grab Setup.vi)
I generated different applications doing changes in the project (additional installer I-IMAQdx 3.2) but I could not run the application yet.
JL
(2,839 Views)
