Problem Reading TDMS File In Chunks
If I understand right, I think you should concatenate the array like this. I haven't tried run this VI, thus I might be wrong in some details.
Message 11 of 14
(1,557 Views)
Hi deppSu, Thanks for the help... Unfortunately, the for loop does not run.. Maybe due to the auto indices? I tried a variety of different wire combinations without success. Is an NI Applications Engineer please able to help? Regards, Jack
Message 12 of 14
(1,533 Views)
All fixed... A very simple solution... Thanks all.
Message 13 of 14
(1,528 Views)
Sorry... Solution below...
Message 14 of 14
(1,524 Views)
