Problem about CPK
I have 30 test result needed to calculate the CPK figure? i make a vi (see the attached). But i find the result is some different from the result that i get use Minitab software. SO pls help me to check the VI ?Thanks!
(3,413 Views)
Are you using the View Process Capability VI in the Spc_demo.llb? If so, it looks like you’re missing the subVI 2D Circular Buffer.vi in your View Process Capability VI. I have attached a screenshot of my View Process Capability VI and you might want to double-check to see if you might have accidentally deleted this subVI from the original VI.
Kileen
(3,372 Views)
hi Kileen:
Not every programm needs this VI. in my application, i think i donot need it . How do you think !
(3,363 Views)
