Problem about Halcon HWindowControl
Every time I run this program shows this error, I have no idea what happened. I am sure that the Halcon DLL is 64bits. can someone help me....
(2,131 Views)
Since you say " I have no idea what happened", was it ever working at one point in the past? Is your LabVIEW 32 or 64 bit?
(2,100 Views)
Here are some suggestions that will help us to better understand your problem and your error.
  • Modify the VI "halconT.vi" by connecting all of the Error In and Error Out connectors with Error Lines.  You will, of course, need to use a Merge Errors function when the upper and lower data flow paths converge on the final HImage property node you show in your too-brief Picture.
  • Run your routine again, this time taking a picture of the Error Message which now should (possibly) tell you exactly which Property Node "threw an error".  If it doesn't, run it with Highlight Execution turned on and watch to see where the Error first appears (or put Probes on the Error Out wires and notice when the first one is activated and report that).
  • While it is sometimes (= rarely) useful to show a "picture of code", it is much more useful (for us, in order to help you) to attach your VI or VIs.
  • Some of us (myself, included) have never hear of "Halcon", nor what sort of hardware this is.  Provide some documentation or link so we know something about this device.  Do they supply LabVIEW Drivers?  If there is a helpful manual, attach it, as well.
  • What is "halcon .net container"?
Bob Schor
(2,094 Views)
