Problem about asynchronous call: subVI front panel doesn't pop up when called.
hi,
 In my vi when i call the subvi the main vi it stops reading the value it works only after i giving a command to the sub vi and when i press ok the sub vi close then it starts working here, is there anyway to programmatically change the behaviour here?
Message 11 of 11
(570 Views)
