Problem about set-up for multi-channel pressure data collection
Hi all:
I am a beginner of NI DAQ.
Now i meet some problems about pressure signal collection (power supplier for pressure transducer is 24v).
firstly, I use 500ohm resistor to transfer the current signal(4mA-20mA) to voltage signal, and then i want to use SCXI1002 and PCI6040E to test these voltage signals.
because the voltage signal cross the resisors are floating signal, so I use two bias-resistors.
But the problem is :
  when I collect one channel pressure signal, everthing is fine,
  but when I want test 2 or more channel pressure signal, the voltage is wrong! (too high).    (I build another 2 bias-resistor for 2nd channel),
 does everybody knows how to set-up multi-channel bias-resistor ?? or is there any problems in my system??
 the electriccal schematic drawing is attached here, anybody knows how big of bias resistor that I should use for multi-channel?? it is very weird, because when I try to change the value of bias resistor, the corresponding voltage is also changed,
(2,747 Views)
This is a duplicate post. Please refer to this link for further information.
In order to maintain the forums in an orderly manner and to keep problem solutions and information in a consolidated fashion easily searchable by customers, duplicate posts are often linked. Best of luck in future applications.
Rod T.
(2,723 Views)
