Problem by acquiring data from Fluke Norma 5000
You can use this driver for the TCPIP-connection as well.
In the description file to the driver you can find how to initialize the TCPIP with VISA.
in my case it was
TCPIP0::192.168.1.101::23::SOCKET
where 192.168.1.101 is the IP from Norma.
(the pdf-file you can download here:
http://forums.ni.com/t5/LabVIEW/How-to-measure-the-current-harmonics-with-Norma-5000/m-p/1295258#M53...
Cheers Alex
Message 11 of 13
(871 Views)
Hi there!
Did you manage to connect with GPIB?? I am having the same problem. NI Max can't recognize my Fluke Norma 4000.... Please write me if you've found the solution.
Thanks!
Message 12 of 13
(704 Views)
It was a couple years ago, but I can remember, it worked properly with Norma-driver.
If you have more than one device connected over GPIB you have to be sure devices have different ID's.
Did you select the right connection type of Norma ?
Cheers: Alex
Message 13 of 13
(694 Views)
