Problem deploying to Multiple platforms from LabVIEW 7
I have an app that runs as a vi file under LabVIEW 7 on both NT and XP without problems, once built into exe file it only runs under XP, if I try to use it on NT I get Error 3008 AUtomation Refnum Class Problem. The vi simply polls a SQL dBase using SQL connectivity vi's and dumps data to Excel 2000. Like I said the vi runs fine as source and Exe on XP but not NT, Any idea's. Additionally I have another app that uses Tree Ctrl in LV7 , runs fine as Vi but when built into EXE the tree ctrl does not populate, again data is being pulled from SQL.
(2,852 Views)
I did a search of the web site and I see nothing about error 3008, however when I searched google, it seems like that is an SQL error about a bad keyword. I am not sure how that would be affected by the VI being an executable. Have you tried a real simple VI that just opens a connection to the database and see if it is successful as both a VI and an exe? Is it any NT computer or just the one?
(2,852 Views)
