Problem in the acquisition of signals by PC sound input, because the Hardware used PCM2902 DAC, there is Inter-Channel Phase Difference
I have a problem in the acquisition of signals by the PC sound input, because the Hardware used PCM2902 DAC, there is Inter-Channel Phase Difference. according to this document:
http://www.ti.com/lit/er/slaz036a/slaz036a.pdf
And I can not synchronize the audio acquisition on the inputs. Do you have any way to do this? Thanks in advance.
Message 1 of 11
(3,894 Views)
Tenho um problema na aquisição de sinais pela entrada de som do PC, porque o Hardware usado PCM2902 DAC, há Diferença de fase Inter-Channel. de acordo com este documento:
E não consigo sincronizar a aquisição de áudio nas entradas. Você tem alguma maneira de fazer isso? Desde já, obrigado.
Message 2 of 11
(3,894 Views)
Hi rd,
according to the PDF there is a phase shift of 1 sample:
- you can "pre-shift" the waveforms before outputting them
- you can "post-shift" the acquired waveforms as needed…
Message 3 of 11
(3,889 Views)
Hello , Thanks for your reply, I'm new to labview, I'm learning. What component could you use to do this? A Wave Generator?
Message 4 of 11
(3,879 Views)
Generation is "mono" only the pickup is stereo, it will generate a single signal and capture it on both channels.
Message 5 of 11
(3,876 Views)
Hi rd,
To "shift" waveforms you could either change the timestamp of the waveform or you could prepend/append samples to the waveform sample array…
Message 6 of 11
(3,849 Views)
I think I'm doing something wrong or not understanding what you told me right. Look what I tried to do, but it did not work:
Message 7 of 11
(3,845 Views)
Hi rd,
you can manipulate each waveform individually using GetWaveformComponents and/or BuildWaveform.
The function you picked will not do what you need…
Message 8 of 11
(3,843 Views)
I can not do it, it did not work.
Message 9 of 11
(3,825 Views)
Accepted by rdeletric
Hi rd,
as long as you only attach images we cannot debug or modify them using LabVIEW…
Both ways to manipulate waveforms I mentioned before are shown in this snippet:
Message 10 of 11
(3,817 Views)
