Problem making a 1 bit picture
I have being trying to make a 1 bit image and I've tried a few ways to do this but have gotten nowhere with it. I hoping someone will see the mistakes I'm making and show me how to fix it, I've attached the program I was working on, the picture I was using is also been attached it might be handy I don't know.
(3,919 Views)
Hi alang,
why do you attach a weird office document when you want to attach a picture?
You could try that to convert a grayscale pic to a "1 bit" picture:
(3,884 Views)
I've tried doing it your way and it only giving me a white picture. It dosen't matter what value I put in the comparitor , any ideas what I should do?
(3,875 Views)
Hi alang,
at first you could attach your picture (after converting it to PNG)!
(3,867 Views)
heres the picture
(3,859 Views)
Accepted by alang1
Hi alang,
by converting to PNG I didn't mean just to rename the file...
Your BMP is a 24bit image, so you have to check the 24bit output of the image conversion routine. Then you simply check a single color component (as it's a gray level pic) for your comparison level:
(3,856 Views)
You are a life saver that was driving me nuts
(3,850 Views)
