Problem measuring accelerometer digital output with pci mio 16-e
Hey folks, I've got a problem with measuring the ADXL210 accelerometer. I am using the DAQ Assistant, as a counter to measure the duty cicle time of the output of the accelerometer. But I have a problem. I just have the DAQ assistant VI and a "data" vi, which shows me the data I am receiving through the board. The problem is that when I run the program. It gives an error message:
Two consecutive active edges of the input signal occurred without a counter timebase edge.
Use a faster counter timebase.
And I have already searched this in this forum and I couldn't solve my problem. Does anyone have an idea? I am placing the cables at the pin 3 (for the signal) and 15 (for GND).
(2,388 Views)
Hi, Follow a link for your query: http://zone.ni.com/devzone/cda/tut/p/id/2751 Diogo
Diogo Aparecido
Applications Engineer II
National Instruments Brazil
(2,328 Views)
