Problem of analog data out from labview to CYDAS1602 DAQ card
Hi all,
I am generating a signal through labview and giving that signal to an analog output vi for CYDAS 1602 (PCI DAQ card). The problem is when I see the output of the Analog out vi, i get only 0 or 1 and not the actual signal value which is generated through Labview. Can anyone help with this?
I have attached the example vi.
Shubham
(2,863 Views)
Hi skb,
I tried opening up your examples, however it looks like you are using both third party hardware (CYDAS 1602) and a software library that was created by Measurement and Computing (das16.llb).  Since I don't have this library and I'm not sure of the functionality of it, I cannot open those examples.  However, I did find a help document on their website that walks you through getting started with that library.
Officially, National Instruments does not support third party hardware so you might find more help contacting the manufacturer of the board for the hardware side or Measurement and Computing for the software.  This also looks like it is a very old PCI board.  You might get better support if you purchased one of National Instruments boards since it can better interface with LabVIEW.  Here is a link to the product page for analog output boards.  Thank you for posting!
Message Edited by Vanessa L on 11-19-2007 01:41 PM
Vanessa L.
(2,843 Views)
