Multi Button / LED Toggle
I would like, when one button is pushed, for its corresponding LED to turn on, and an action to take place by turning True.  At the same time I would like the other LEDs to turn off, and have all the other actions to turn False.  This system will need to be in a loop so that it is possible to go back and forth between buttons ("systems of flight").
Example:
Button 1 Pushed :: LED 1 On :: System 1 True
Button 2 Off :: LED 2 Off :: System 2 Flase
Button 3 Off :: LED 3 Off :: System 3 False
Then:
Button 1 Off :: LED 1 Off :: System 1 Flase
Button 2 On :: LED 2 On :: System 2 True
Much Appreciated,
Jim
Message 1 of 11
(6,857 Views)
Here is the part of the file that applies to this post (see attached).
- Jim
Message 2 of 11
(6,840 Views)
Hi Jim,
I think this is a problem where the "Event Structure" comes in really handy.
See what you think...(attached VI)
Mark H.
P.S. Unfortunately I can't open your previous attachment as I only have LV 7.0 on my home PC (7.1 & 8.0 at work).
Message Edited by Mark H on 10-29-2007 08:33 PM
Message 3 of 11
(6,826 Views)
No real code needed. Use a "radio button control".
If you replace the contents with a "Push button" you'll have the LED built-in. 🙂
If you wire the radio button control to a case structure, it will act like an enum and label the cases accrding to the control labels.
Message 4 of 11
(6,825 Views)
Here's an example (LV 8.0) using the radio button control.
Message 5 of 11
(6,815 Views)
Hum... The stop button deserves a better treatment : to leave the program, the task must be changed. 😮
Add an event specifier to track also a value change of the stop.
Message Edité par chilly charly le 10-29-2007 10:57 PM
Chilly Charly    (aka CC)
Message 6 of 11
(6,799 Views)
Yes, I forgot to add an event for the stop button press. 😄
This is just skeleton code. Modify as needed. Most likely you want a seperate event case for the stop button.
Message 7 of 11
(6,788 Views)
this is what I finally decided to use.
thank you all
- jim q
Message 8 of 11
(6,703 Views)
No. You were already told to wire the output of the case statement to the VISA Write. You still have a race condition.
Message 9 of 11
(6,696 Views)
No wories. That isn't my full code; it's just a sample. It's wired the right way where it matters.
This just shows the wiring pattern for the Event Structure.
Message 10 of 11
(6,682 Views)
